Discussion topic: Home WiFi not working
This message was authored by: btno3
My home WiFi is not working properly. It's intermittent at best but has been off longer than it's been on for the last 24 hours.
Re: Home WiFi not working
@btno3
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Avatar for btno3
Hi there. Done all those tests sent in the previous message. All say everything is fine but my WiFi box still only has the top light showing.
Avatar for btno3
I don't have a landline phone in my house so can't call 150 to report the issue.
@btno3
You have a Sky Talk landline as it's bundled with your broadband package but you  have chosen not to connect an actual handset which is fine.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
