Discussion topic: Sky Broadband With 3rd Party Router
This message was authored by: veedub606
Morning All,
I'm having a dilemma with Sky broadband at the moment, all I want to do it swap to a TP Link AX3000 router.
I've followed the steps via the TP Link and I have no internet access, I've spoken with TP support and spent hours trying to sort something that should be plug and play.
I have fibre coming into the house via open reach white box - TP Router via blue WAN port.
Any help is greatly appreciated
Re: Sky Broadband With 3rd Party Router
@veedub606 unfortunately TP-Link dont support the authentication system Sky use on their UK services. You need support for DHCPv4 Option 61 which Asus and Netgear routers generally offer. You may suceed connecting your TP-Link unit by using DHCPv6 PD but thst depends on the kit at the exchange supporting it which not all do.
Avatar for veedub606
Can you recommend a Asus router capable??
@veedub606
Any of the RT-AC/AX series really
I am NOT a Sky Employee
I've gone with the Asus AX59U but still having the issue of no internet access
Hi @veedub606
Please post screenshots of your configuration on the Asus router
