Discussion topic: my internet connection keeps loosing connection for a shorty while,
This message was authored by: Annette16
hi my internet connection keeps loosing connection for a shorty while, i also cannot access my admin page for my router,  it wont load the page at all, tired on my msi laptop and iphone, i have tried factory resetting my router and restarting it but both problems persists. thanks
Re: my internet connection keeps loosing connection for a shorty while,
@Annette16 what happens tonthe LEDs on the hub when you lose connection? The LEDs help you to work out what is happening see https://www.sky.com/help/articles/hub-lights-explained-start
Avatar for Annette16
Hi thanks for the reply. My internet LED goes orange for a few seconds then comes back to green.
This message was authored by: itsajay99
I've been having the same problem too 😕
Hi @Annette16
Please post your router stats
I am NOT a Sky Employee
@itsajay99
If you want help please post your own thread
Hello,
here are my router stats
System Detailshelp
ManufacturerSky
ModelSR203
Firmware Version7.03.0509.R
DSL Firmware VersionA2pvfbH043p1.d26u
Modemhelp
Modem StatusConnected
Traffic Type:PTM
Line Rate - Upstream (Kbps):16995
Line Rate - Downstream (Kbps):32400
IPv6 Loopback Address2a02:c7e:2ea4:d000::1/128
Broadband Porthelp
MAC Address80:75:1f:64:d1:1a
IPv4 Address94.194.79.72
Network TypeMER
IPv4 Subnet Mask255.255.252.0
Gateway IPv4 Address94.194.76.1
IPv4 Domain Name Server90.207.238.97, 90.207.238.99
Gateway IPv6 Addressfe80::22
IPv6 Domain Name Server
IPv6 Global Address2a02:c7e:2ea4:d000::1/64
IPv6 Link Local Addressfe80::8275:1fff:fe64:d11a
IPv6 Delegated Prefix2a02:c7e:2ea4:d000::/56
LAN Porthelp
MAC Address80:75:1f:64:d1:19
IPv4 Address192.168.0.1
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULAfd6d:e154:2545:0:8275:1fff:fe64:d118/64
IPv6 Link Local Addressfe80::8275:1fff:fe64:d119
DHCPv6On
WiFi Porthelp
Name (SSID) SKY85IBD
Region Europe
Current Channel 6 (2.4 GHz), 36 (5 GHz)
WiFi AP Enabled
Broadcast Name Yes
thanks
It might be these stats instead apologies for the confusion
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 25086 172554 0 92773 123332 00:07:40 LAN Up 6729242 5649598 0 78934 62576 44:43:02 WLAN (2.4 GHz) Up 1470592 347774 0 484 0 44:41:13 WLAN (5 GHz) Up 13204198 5276340 0 0 39750 44:41:11
Broadband Link Downstream Upstream Connection Speed 32400 kbps 16995 kbps Line Attenuation D1(11.3 dB) , D2(23.7 dB) , D3(36.6 dB) U0(0.1 dB) , U1(17.6 dB) , U2(26.3 dB) Noise Margin 11.6 dB 9.4 dB
Hi @Annette16
I can see that your line is dropping and your stats suggest a line fault. Please can you run the line test in the My Sky app to see if that allows you to book an engineer? If it doesnt we can escalate your post here to chat with a Sky rep.
