Discussion topic: Setting up TP link VR2800
Message posted on 12 Aug 2025 10:35 AM
Hi can anyone help me set up my tp link vr2800 modem router with sky fibre.
Message posted on 13 Aug 2025 11:23 AM
Re: Setting up TP link VR2800
Hi @Susannet3
Is it full fibre or part fibre you have? Also are you located in the UK or Ireland?
Message posted on 13 Aug 2025 12:08 PM
Hiya full fiber and in the uk
Message posted on 13 Aug 2025 12:13 PM
Hi @Susannet3
In that case it should be as simple as connecting your router from the LAN port on your Openreach ONT to the WAN port on your TP-Link router, then configuring it to use Automatic IP on the WAN & enabling IPv6 so that it can authenticate automatically via IPv6 PD.
