Discussion topic: Intermittent drop out
This message was authored by: Karen_Windle
I'm having the above challenge since 09.30 to  date/ time. It's micro dropout, 1-5 seconds at most. However, it is hugely frustrating, as I've been on virtual meetings all morning. Carried out a speed test, checked outages and none are reported.
Re: Intermittent drop out
Hi @Karen_Windle
Have you tried rebooting your router?
Are you able to try ethernet?
I am NOT a Sky Employee
Avatar for Karen_Windle
No, not restarted the router and unable to use Ethernet cable owing to placement. Will reboot router later as on meetings all day. ☺️ Thanks.
