Discussion topic: Second hand router
This message was authored by charlielewis01 This message was authored by: charlielewis01
Second hand router
I have brought a second hand router as my original one became faulty. Can I plug the router straight in or do I need to register it with sky?
Re: Second hand router
@charlielewis01
Its always best to request a new router from sky especially if its an sr203 or issued after april 2020. These hubs are loan items and should have been returned to sky.
@charlielewis01
If your router is faulty you should get Sky to send you a replacement FOC. Any router you buy online is not owned by the seller and is loaned from Sky. If you start using it there is a very good chance Sky will brick the router and it'll stop functioning.
I am NOT a Sky Employee
