Discussion topic: Saying no Internet connection
This message was authored by: Krystale
Saying no Internet connection bit checked otherwise and saying it's good bit not able ti connection
Re: Saying no Internet connection
@Krystale
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
