Discussion topic: Abridge essex
This message was authored by: Abridge
Abridge essex
We have big problems with sky in abridge essex, sky no WiFi at all just charging money,but not provided service at all
Re: Abridge essex
@Abridge
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
