4
Discussion topic: SKY SR102 Hub - Can these be used as a repeater or any other uses
This message was authored by SteveLP This message was authored by: SteveLP
Switching from sky but seems a waste just to bin it and I do need extra ethernet connections in another room. Can these be used as as repeater either wired or wirlessly. Or failing that any other uses for them other than recycling.
Basically looking for it to give me ethernent points in another room rather than as a wifi extender.
This message was authored by TimmyBGood This message was authored by: TimmyBGood Answer
Re: SKY SR102 Hub - Can these be used as a repeater or any other uses
@SteveLP
The 102 is single band (2.4Ghz) 802.11n and a decade old: that's really not particularly desirable in any role.  You might get a few quid on eBay, I guess, but while still in support this model is essentially obsolete.
@SteveLP
The only thing it would be good for is recycling
@SteveLP
SteveLP
Thanks for the replies, thought that may be the case as even I've been using a different router for my Sky  login. Forgotten they were 2.4 only, was gonna give my newer one to a friend but guess I'll use that as my repeater as pretty sure that can do it and 2.4/5 bands too.
Recycling it is.
@SteveLP
Be aware that all Hubs acquired after 2019 (and some before then) are loaned by Sky, not sold, and so can't legitimately be retained or passed on.  Sky expects these to be returned, and there's a penalty fee for not doing so.
