1
This discussion topic has been answered Discussion topic: Router won’t connect with sky box
This message was authored by: Lolalola1
Can't connect sky box to the router, have followed instructions on resetting but still doesn't connect
This message was authored by: Nick2290 Answer
Re: Router won’t connect with sky box
Hi, if your router is one of the new white ones it might be worth trying to install q box network connection using the non standard Sky router option on the Sky q settings/network you will need to type the password etc yourself.
