Discussion topic: Router upgrade 500
Message posted on 13 Apr 2025 02:31 PM
Router upgrade 500
Im currently on the 500mb package but can only reach speeds of 250 ish with the Sr203 , i have wifi 6 capable devices how to i obtain the newer wifi 6 router?
Message posted on 13 Apr 2025 02:32 PM
Re: Router upgrade 500
By calling Sky and signing up for the WiFi Max subscription supplement.
Message posted on 13 Apr 2025 06:46 PM
@cjenkz22 Wi-Fi 5 connected laptop to an SR203 Router about 15 foot away and FF500 sky package, speed test to fast, result picture.
Ethernet connected, arround the 490 mark consistantly... Suspect not your router at issue.
SR203 to Asus Laptop wireless
Message posted on 15 Apr 2025 08:02 PM
Thanks for the replys , would a second hand one from ebay work as i dont want to sub to sky max.
Message posted on 15 Apr 2025 08:09 PM
@cjenkz22 You can't purchase 2nd hand Sky broadband or Sky Max hubs as these are loaned to the customer, any you see are classed as stolen property.
Message posted on 15 Apr 2025 08:11 PM
Ok i didnt know that and will avoid , thanks
Message posted on 15 Apr 2025 08:12 PM
@cjenkz22 Do your research and look at Asus as the router direct on your ONT, but only if you are not using a landline via sky!
