Discussion topic: Router resets
This message was authored by: AlexaScotcher
Message posted on 11 Mar 2026 11:48 AM
Router resets
Hi there, We are having to reset router every day, surely this is not right?
Find out more
Message posted on 11 Mar 2026 11:53 AM
Re: Router resets
@AlexaScotcher it isnt normal. Why are you resetting the hub? Sky hubs should automatically reconnect once any fault on the line clears. In practice you should only reset the hub every few months if then.
