Discussion topic: Router problems
Message posted on 04 Oct 2024 05:57 PM
Router problems
Router issues. It tells me to press the WPS button for at least 3 seconds. I've done this several times now and the tv screen stays on this page with nothing hapening
Message posted on 04 Oct 2024 06:20 PM - last edited: 04 Oct 2024 06:21 PM
Re: Router problems
It helps if you identify what you are trying to achieve.
WPS pairing typically needs a trigger (button press) on both the router and the device which needs an internet connection.
Message posted on 06 Oct 2024 12:15 PM
Re: Router problems
I have now got the issue sorted, thank you.
