Discussion topic: Router lights
This message was authored by: Tarn4
Router lights
My broadband hub is showing green amber green amber. SkyTV and WiFi have gone off.
It's been fine until now.
Re: Router lights
@Tarn4
Unlikely to be overnight essential maintenance on a Sunday night into Monday morning.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
