Discussion topic: No Internet - hub slow flashing green
Message posted on 24 Nov 2025 12:43 AM
Hi, I have no Internet and the hub is slowly flashing green. My internet was connected 3 days ago and been working fine until now.
Message posted on 24 Nov 2025 04:28 AM
Re: No Internet - hub slow flashing green
@Da123n
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
