Discussion topic: Router is not working
This message was authored by: Loocie
I have full fibre and the light on my router is red, no internet, can any advise please
Re: Router is not working
@Loocie
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
