Discussion topic: Router for fibre broadband
Message posted on 13 Jun 2025 02:44 PM
Re: Router for fibre broadband
Thanks for all your help , guy at sky didn't tell me any of this , I don't have a landline phone anymore so that's one thing I don't need to worry about....
Message posted on 13 Jun 2025 02:46 PM
- Just one last thing , once everything is in and ethernet cable connected do I need to configure anything in the router ?
Message posted on 13 Jun 2025 02:58 PM
@edgie700 Since you are just moving from the old copper fttc connection to the new fibre ONT, it's a DSL cable disconnect, your new RJ45 cable the 8M one you are getting plugged into Lan port 4 WAN port, plugged into the LAN off the ONT once OR install team is happy it's installed, they watch the ONT light sequence so they KNOW it's updated its FW, green lights on the ONT he/she the installer will say ok we are good to go, can we swap over, yes say's you cable is lying there ready for you to plug it in. Fingers crossed Fibre up your connected, all green lights across the board on the SR203 you are good to go, do quick speed test to quickly check, DONE!.
With regards to the hub and it does not matter if or if not, but the set connection to WANoE rather than Auto, but both work fine....
Message posted on 13 Jun 2025 03:09 PM
Thank you so much for all your help , really appreciated
Message posted on 13 Jun 2025 03:36 PM
Message posted on 13 Jun 2025 04:22 PM
I'll see how it is after it's installed ( just got off the phone to sky , all ordered ) and change to that if necessary, thanks
