Discussion topic: Sky hub 4.2 replacement set up issue
This message was authored by: SAL31
I have received my replacement hub but the black lead that goes into the phone socket isn't long enough. Can I use my existing one that goes into my old hub?
Many thanks
Re: Sky hub 4.2 replacement set up issue
@SAL31 Yes would be the answer to that, same cable so should not be an issue!
Avatar for SAL31
Brilliant! Thank you - I'll give that a go. 😊
@SAL31 You will know fairly quickly new hub and established Internet light to green, hub should do a FW update shortly after that if it needs one, so may just update and then re-boot itself, just the heads up.👍
Avatar for SAL31
Thanks again - it all seems to be working!
Does anyone know if I have to send back the old router?
Many thanks
@SAL31 What is it that you have the old sky Q ER110/115 model, if so would not think that sky would want it back or deal with the posting involved in doing so! If the did or supplied return pacaking then yes, pop it back to them!
Avatar for SAL31
Hi It's a SR101 They didn't supply a returns label or say anything about returning it so I'm guessing they don't want it back??
@SAL31 Getting to be a museum piece that one, prosperty, managed to skip it from the Dlink to the skyQ, then onto the SR203 Broadband hub, still got the two originals, nostalgia....
Avatar for SAL31
🤣It is quite old!!
@SAL31 Yes and don't we know that! Time for it to be retired it has served you well for all those years!
This message was authored by: edgie700
Is that the Sr203 ? Hub 4.2 ?
Avatar for SAL31
Hi
Yes my new one is sr203 and the old one is sr101
