Discussion topic: Router dropping out overnight
This message was authored by: Rodders78
Hi,
Ive read many posts about sky routers dropping out overnight which mine does.
Ive adjusted all of the eco modes on the skyQ boxes and am still finding the same issues. Normally its not an issue but I get a notification that my home security is down at the time theoretically I want it working.
Ive checked router settings and can't see any obvious settings and have copied the log. Is anyone able to shed any light or give any advice from the log report please as I don't have a clue, thanks.
2024-07-11   18:50:16 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   18:56:00 syslog: WAN IPV6 UP
2024-07-11   19:23:16 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   19:26:00 syslog: WAN IPV6 UP
2024-07-11   19:42:25 syslog: Send out NTP request to ntp1.isp.sky.com
2024-07-11   19:42:26 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-07-11   19:42:26 syslog: System time is up to date
2024-07-11   19:56:00 syslog: WAN IPV6 UP
2024-07-11   19:56:35 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   20:26:00 syslog: WAN IPV6 UP
2024-07-11   20:26:53 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   20:56:00 syslog: WAN IPV6 UP
2024-07-11   21:01:23 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11    21:26:00 syslog: WAN IPV6 UP
2024-07-11   21:35:17 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   21:56:00 syslog: WAN IPV6 UP
2024-07-11   21:59:35 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   22:11:21 syslog: Send out NTP request to ntp1.isp.sky.com
2024-07-11   22:11:22 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-07-11   22:11:22 syslog: System time is up to date
2024-07-11   22:26:01 syslog: WAN IPV6 UP
2024-07-11   22:31:05 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   22:56:01 syslog: WAN IPV6 UP
2024-07-11   22:58:59 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   23:26:01 syslog: WAN IPV6 UP
2024-07-11   23:30:48 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   23:55:06 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-11   23:56:01 syslog: WAN IPV6 UP
2024-07-12   00:26:01 syslog: WAN IPV6 UP
2024-07-12   00:27:30 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   00:29:58 syslog: Send out NTP request to ntp1.isp.sky.com
2024-07-12   00:29:59 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-07-12   00:29:59 syslog: System time is up to date
2024-07-12   00:55:42 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   00:56:02 syslog: WAN IPV6 UP
2024-07-12   01:26:02 syslog: WAN IPV6 UP
2024-07-12   01:31:06 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   01:56:02 syslog: WAN IPV6 UP
2024-07-12   01:59:18 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   02:26:02 syslog: WAN IPV6 UP
2024-07-12   02:32:01 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   02:33:10 syslog: Send out NTP request to ntp1.isp.sky.com
2024-07-12   02:33:10 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-07-12   02:33:10 syslog: System time is up to date
2024-07-12   02:56:02 syslog: WAN IPV6 UP
2024-07-12   02:56:54 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   03:26:02 syslog: WAN IPV6 UP
2024-07-12   03:29:00 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   03:56:02 syslog: WAN IPV6 UP
2024-07-12   04:03:12 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   04:26:02 syslog: WAN IPV6 UP
2024-07-12   04:33:13 syslog: Lease renewed 3600 ip 90.218.78.96
2024-07-12   04:39:25 syslog: Send out NTP request to ntp1.isp.sky.com
2024-07-12   04:39:25 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-07-12   04:39:25 syslog: System time is up to date
Re: Router dropping out overnight
@Rodders78 the network is can drop overnight for a number of routine reasons which is why well engineered alarm systems should cope.
Causes include
  • DLM resets on FTTC lines to stabilise the line
  • Firmware upgrades and housekeeping on Sky hubs
  • System upgrades and maintenance
These are unavoidable and while you can go literally months without an issue overnight you can get periods with frequent interuptions. If you need 24/7 connectivity you need an alarm system with a SIM card for fall back.
