1
This discussion topic has been answered Discussion topic: Ring doorbell
This message was authored by: me1485
Ring doorbell
Since installing the upgraded WiFi my ring doorbell and camera are showing a red triangle and the word CRITICAL. The batteries are all charged up and when I investigate through the app it shows "we're having trouble connecting. Please try again."
This message was authored by: JimM1 Answer
Re: Ring doorbell
@me1485 If your hub moved, or you have not reconnected then that will be the issue, so it's either that or moved the wifi signal is not reaching, have a look on the ring app, RSSI needs to be down below the 60's if possible!
Re: Ring doorbell
