Discussion topic: Ring doorbell causing WiFi dropiut
Message posted on 08 Sep 2025 04:18 PM
Message posted on 08 Sep 2025 04:37 PM
							Re: Ring doorbell causing WiFi dropiut
@themanc55 Have a look on your ring app, front door settings, device health and say what your Signal Strength RSSI value is at!
Message posted on 08 Sep 2025 05:01 PM
It says it's 59
Message posted on 08 Sep 2025 05:06 PM - last edited: 08 Sep 2025 05:10 PM
@themanc55 You are on the hairy side for ring lower RSSI takes it way better, current value on mine 42, but had to fit a powerline to stabalise it, what sky Hub do you have it all connected too, see the link below if not sure about hubs!.
Understanding wifi recommendations for Ring devices
Message posted on 08 Sep 2025 05:22 PM
I have the sky Max hub.
The doorbell seems fine, I just don't understand why my WiFi in the rest of the house now is terrible.
If I do a test on the broadband everything comes back as fine, but it's not sadly
Message posted on 08 Sep 2025 06:03 PM
@themanc55 If you suspect that it is the ring doorbell, turning the three options off, Ring allerts, motion detect and motion alerts!, see what happens then!
