3
This discussion topic has been answered Discussion topic: Ring door bell goes offline when sky q updates
This message was authored by: G0606777
Over the past 4 weeks my ring doorbell as started to drop offline. As far as I can see this is coincident with Sky Q updates at 6 in the morning. I have put in an extender to give perfect signal to the doorbell and changed the doorbell but this hasn't helped.
Re: Ring door bell goes offline when sky q updates
@G0606777
See this link and adjust the settings on your Sky Q to none and see if that helps
https://www.sky.com/help/articles/using-the-standby-settings
@G0606777
Avatar for G0606777
Many Thanks, that sounds like it could help as the device is generally going off over night. Will give it a go and let you know.
@G0606777
Perhaps note that while changing that setting should disable the overnight low power mode there's no way for a user to prevent a Q box from doing a periodic reboot, which they do automatically to remedy a memory leak: if this is an issue for your camera coverage then using the Q hotspot functionality isn't ideal.
