Discussion topic: Ring device ls
Message posted on 06 Jan 2024 04:51 PM
Ring device ls
I have no connection to my ring products and I have made the router wpa2 as I couldn't get the ring devices to work at all
anyone else have same problem
Message posted on 07 Jan 2024 08:37 AM
Re: Ring device ls
@Nickle42 are your Ring products connecting but then losing connection or never connected at all. Some older Ring oroducts have issues connecting to dualband SSIDs. If as it sounds like you havectge new Wifi Max white hub tge process is to temporarily turn off the 5GHz band using the My Sky app tgen connect the devices using the app then switch the 5GHz band back on. For other hubs use these instructions Split Sky WiFi bands
Message posted on 08 Jan 2024 09:30 AM
Re: Ring device ls
Hello
this change over to sky has been very stressful and I'm am very sorry I changed over
the black router was useless and the white max WiFi hub has many problems I am disappointed that the unit wpa2 is not compatible with most smart switches or ring devices either nothing works all my ring equipment is new but will not connect the sonoff switch's won't connect and many othe makes are the same the WiFi network is terrible
Message posted on 08 Jan 2024 10:05 AM
Re: Ring device ls
@Nickle42 I have new White Sky Hub but don't have any issues with my two Ring Devices and they connected to it fine.
Message posted on 08 Jan 2024 10:42 AM
Re: Ring device ls
@Nickle42 if you have Sky's Wifi Max bundle simply call Sky and book an enginer to come out to sort your wifi for you. The default Wifi security setting on the white Wifi Mx router of WPA3-T is compatable with most Wifi devices that support WPA2 certainly none of my own devices refused to connect.
Message posted on 08 Jan 2024 03:06 PM
Re: Ring device ls
I have lots of ring devices they all won't connect to the new white sky hub max the epa2 is not compatible with the old type or new
I have lots of equipment not connecting
Message posted on 08 Jan 2024 03:18 PM
Re: Ring device ls
@Nickle42 if you buy Wifi Max service, which is the only normal way to get the SR213 white, hub Sky will send out an engineer if you are having wifi issues.
