Discussion topic: Ring chime
This message was authored by Discus1262 This message was authored by: Discus1262
Ring chime
Recently changed my sky router & now my ring chime won't keep its connection
the door bell is fine just the chime connects then goes off line after a short time
any help would be appreciated
Re: Ring chime
@Discus1262
Have you set it up with the new wifi password on the ring app :-
https://support.ring.com/hc/en-gb/articles/115001773546-Setting-up-your-Ring-Chime-in-the-Ring-app
Discus1262
Re: Ring chime
Yes used new Wi-Fi details the door bell/ camera is fine never drops off but the chime Connects for a short time then just starts flashing it's offline
tried different outlets  and it's in the same room as my router just won't stay connected 🙄
Re: Ring chime
@Discus1262
When you rec'd the new router did you seperate the wifi bands
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
