Discussion topic: Reload hub
This message was authored by: Really+sky
Reload hub
I can't reload hub
it just says web page not available
ERR_INTERNET_DISCONNECTED
no outstanding balance on ac
Avatar for Really+sky
Re: Reload hub
Can't reload Hub
 Bills all up to date , tried everything
Re: Reload hub
@Really+sky  That nmessage has nothing to do with your account status, that is a message, have you tried pressing the rest button on the hub?
Re: Reload hub
Yes tried the reset button, i get as far as reload hub and that's it
Re: Reload hub
@Really+sky
If internet is working on other devices then the problem isn't an account issue.
That appears to be a smart television: are you trying to connect it for the first time?
Re: Reload hub
No the wi fi not working on other devices
not first time to connect
Re: Reload hub
@Really+sky
In that case, what are the lights on the Hub?
