Discussion topic: Reduced WiFi
Message posted on 01 Apr 2025 06:37 AM
Reduced WiFi
We recently switched from BT to Sky, and while our WiFi coverage tests indicate a strong signal, we’re experiencing weak connectivity in certain upstairs rooms and areas of our home.
Could you advise on how to resolve this issue? Do you offer WiFi boosters or extenders to improve coverage in these areas?
Message posted on 01 Apr 2025 07:29 AM
Re: Reduced WiFi
@mik43 youare not talking to Sky by posting in the forum. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
