Discussion topic: Red light LOS on ONT
Message posted on 31 Mar 2025 12:56 PM
No signal, need help. Switched everything on and off 10 times. Still seems I have a loss of service in the Cardiff area. Any ideas on the Red LOS light on ONT box?
Message posted on 31 Mar 2025 01:04 PM
Re: Red light LOS on ONT
You would need to call sky to report it
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Message posted on 31 Mar 2025 01:06 PM
@chopra5 simply means the ONT has Lost its Optical Signal. Unless the Service checker in the My Sky app run over a mobile connection tells you Sky are already aware of an issue affecting your line then call Sky to report it. Openreach will need to check the connection which is normally done within 2 to 3 days.
