Discussion topic: Red internet light
Message posted on 06 Jul 2026 08:33 PM
Red internet light
I currently had no internet. I have turned the router n and off, and the internet light is still red and all devises are saying that they cannot connect as no network
Message posted on 06 Jul 2026 08:36 PM
Re: Red internet light
@Lauraashwood
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
