This discussion topic has been answered Discussion topic: Internet keeps dropping out
Message posted on 06 Jul 2026 08:39 PM
Message posted on 06 Jul 2026 08:50 PM
@JakeGarvey88
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
@JakeGarvey88
