Discussion topic: Intermittently slow wifi
This message was authored by: DeanEvans
Im 100% confident that I have a problem with my WiFi in this house and in the last week its got worse. Sky says there's nothing wrong and the test results back them up. The speed is okay (which it wouod be when it works) ane they even run a test for a week. After a week they called and asked if there were any issues- id expect them to know the answer!! Its really frustrating!!
Re: Intermittently slow wifi
@DeanEvans
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
