Discussion topic: Recently had upgrade of broadband! But as slow?
Message posted on 29 Apr 2025 09:25 PM
Message posted on 29 Apr 2025 09:55 PM
Re: Recently had upgrade of broadband! But as slow?
@MJADAMS11 From what to what have you done, and with what expectation are you looking for? Have a read also when you get some time.
https://www.sky.com/help/articles/broadband-speeds-explained
Message posted on 30 Apr 2025 07:42 AM
Appreciate the links, etc, but I have spent the last 7 years waiting for fibre upgrade(so aware of said links!!) gone through the process of only using 1 gadget at a time etc!...i guess cos i live in a remote area(thankfully) IT IS WHAT IT IS ;)...but will be phoning Sky for a discount..Thanks again ...have a great day
Message posted on 30 Apr 2025 08:30 AM - last edited: 30 Apr 2025 08:44 AM
Is your broadband now 'full fibre' or 'fibre to the cabinet'?
FTTP should be the same everywhere becomes optical cable effectively removes the impact of location. By contrast, FTTC is critically distance-dependent and inherently limited: it's not entirely impossible that FTTC can actually perform worse than the preceding ADSL.
Message posted on 30 Apr 2025 08:48 AM
@MJADAMS11 something thst many customers find after upgrading speed is thst the bottle ne k was not the connection speed to the hub but rather the speed of the wifi connection in the home.
