Discussion topic: No broadband connection
This message was authored by: Merryfield
My broadband connection keeps dropping.
Re: No broadband connection
@Merryfield
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Avatar for Merryfield
Hi Daniel0210
Well the link was on and off for the past hour so the test could not complete.
It seems to be back up now but don't know for how long.
Broadband
What is going on, my broadband is up and down like a yoyo, this is not the service I expected. PLEASE SORT THIS OUT.
Re: Broadband
@Merryfield
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
Re: Broadband
and typing in capitals doesn't get you service any quicker!
Thanks for the info but none of this will work if you have no connectivity and I do not have a brabant phone so cannot dial 150 for support.
Why does sky not have an email for these issues and support?
@Merryfield
What's a Brabant phone?
Sky don't use email for general communication or fault reporting. It's very difficult to confirm the person contacting by that method is the account holder.
If you don't have a landline connected to Sky Talk or a Sky mobile use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Sorry about the typo it should read broadband.
Thanks for the info hopefully I can get some answers.
