5
This discussion topic has been answered Discussion topic: Receiving a GRE error when connecting to work VPN
This message was authored by: Tommyc28
I receive the above error when connecting to my work VPN. How can I allow Generic Routing Encapsulation on my Router?
I've tried port forwarding and disabling the broadband shield already.
I've also set up new firewall rules on my laptop to allow GRE and specifically port 1723 as advised online.
The issue still persists so it must be relating to my Router.
Re: Receiving a GRE error when connecting to work VPN
@Tommyc28
Then it's almost certainly a problem related to Sky deploying 8:1 Map-T IPv4 address sharing.  You'll need to fill in the form linked from the pinned post at the top of this forum, which is effectively a request to have Map-T removed from the circuit to the property.
@Tommyc28
Do you have a white Sky Max Hub or a black earlier model?
Avatar for Tommyc28
Level 0 icon
Thanks for getting back to me - I have a white sky max hub
@Tommyc28
Avatar for Tommyc28
Level 0 icon
Thanks for your help. Appreciate it.
@Tommyc28
You could also try toggling UPnP  through the Hub administration settings in the My Sky app: this moves Map-T from 8:1 to 1:1 which solves some VPN issues.
