Discussion topic: Really poor connection on devices
This message was authored by: Paula4812
Message posted on 10 May 2026 02:28 PM
My phone and laptop all have poor connections and are really slow with the signal strength showing as poor. Also the PlayStations connected lag as well.
Find out more
Message posted on 10 May 2026 04:24 PM
Re: Really poor connection on devices
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
