Discussion topic: Broadband out
Message posted on 10 May 2026 04:28 PM
Broadband out
We have no broadband. The red PON light is on the fibre box. The tests on the app says everything is ok. It is not
Message posted on 10 May 2026 04:33 PM
Re: Broadband out
@Muck
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
