Discussion topic: Really poor WiFi!!!
This message was authored by: Simon223
Message posted on 01 Jan 2025 01:47 AM
Really poor WiFi!!!
Awful/non existent wifi. No signal, broadband check says ok, clearly not!
Find out more
Message posted on 01 Jan 2025 05:52 AM
Re: Really poor WiFi!!!
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
