Discussion topic: Problems with Internet
This message was authored by: Baz1111
I cannot connect to the internet. Off the three green lights, the middle one is orange. I cannot connect my phone, TV or Television. Yet when I run the service checker with Sky, you show all green ticks for everything, even wifi
This message was authored by: samspedding
Re: Problems with Internet
Mine is the same
Avatar for Baz1111
They'll be getting a call in the morning👍
This message was authored by: Em389
I've just checked the Sky service area checker page and it seems lots of areas will be down from midnight to 6am. Not sure if any of your areas are affected however, it does say it's for fibre work so might be good in the long run if you're looking to get fibre. Shame they couldn't send a text to let everyone know though.
This message was authored by: Polykarpos
Mine is down too. Had a deadline to complete this morning I received no notification from Sky !!! Simply I missed the deadline and all the paperwork related to it
This message was authored by: Larisasa
Wifi issues
My WiFi just stopped connecting
This message was authored by: haq97123
Re: Wifi issues
Hi,
where are you located? Mines been down for an hour and light is just flashing green
I'm having the same issues in Lancashire, sky max hub just showing flashing green. Glad I'm not the only one but still sucks
I saw that list was for Aberdeen, I'm based in Lancashire. Their communication is not exactly brilliant, not sure why I changed from virgin as they would give you plenty of notice of any downtime
Re: Wifi issues
Blackburn.
qhen I test it, it says good connection, but last checked 2 hrs ago even though I test it now
Re: Wifi issues
Mines are: green, orange, green and orange
Re: Wifi issues
I'm in Blackburn too! Small world, clearly it's a widespread issue then
Re: Wifi issues
Defo small world lol
ota annoying as I was working on my presentation for tomorrow 🫣🤨
This message was authored by: Lijo
Re: Wifi issues
My wifi also stopped connecting
Re: Wifi issues
I've had to just hotspot my phone, not ideal but better than not getting any work done!
