Discussion topic: Problems with E Mail
This message was authored by Tema8Kaan This message was authored by: Tema8Kaan
Constantly waiting for E Mail to download. Solar Panel battery array Wi Fi very erratic in waking up. Both these issues did not exist under Virgin. Spoke with Sky technician and he blamed Yahoo. But not prepared to get into Ping Pong with them. Any advice please
Re: Problems with E Mail
@Tema8Kaan
Try disabling Sky Shield
I am NOT a Sky Employee
Tema8Kaan
Thanks for quick reply, but how? What implications are there?
@Tema8Kaan
You can configure it here https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Its only basic DNS filtering for sites depending on the age category you select so it isnt a security issue to disable it
Tema8Kaan
a bit delayed, sorry. Default is Shield disabled
@Tema8Kaan
Hmm okay, if you have an Apple device can you try disabling iCloud relay? https://support.apple.com/en-sg/guide/iphone/iph499d287c2/ios
Also please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
Tema8Kaan
Private relay is not on.
Tema8Kaan
Router statsRouter Stats P2
@Tema8Kaan  The images you posted are not your router stats, as they show your public IP the images can't be shown please follow the steps provided by @jamesn123  to the very end.
Tema8Kaan
Not sure about pasting links on ipad, has this worked?
http://192.168.0.1/sky_system.html
@Tema8Kaan
I am not sure how much clearer we can be. Nobody asked you to post a link, please follow the step by step instructions to the end.
Tema8Kaan
Following the instructions didn't work. I got an error message suggesting something wasn't entered right, hence the paste, can you still add anything for me?
@Tema8Kaan
Only thing I can suggest is if your using an Apple device then use a different, non Apple device. Sometimes you cant login with Apple devices, or at least using Safari
Tema8Kaan
Thanks for your help but we only have Apple devices in the household
@Tema8Kaan
Then download a different browser other than safari like I said.
