Discussion topic: Problems since yesterday but WiFi saying good?
Message posted on 02 Feb 2025 04:03 PM
WiFi is not working, devices cannot connect, stating WiFi is off when its plugged in and on with 4 green lights? We've reset it, turned it off, restarted devices, etc, left it till the morning to see if it would resolve itself but nope, any ideas? Thank you 🙂
Message posted on 02 Feb 2025 04:15 PM
Re: Problems since yesterday but WiFi saying good?
I've had problems since yesterday too, getting worse passed hour, internet keeps going off
Message posted on 02 Feb 2025 04:29 PM
Message posted on 02 Feb 2025 05:00 PM
Super annoying, trying to get an answer from them is difficult also!
Message posted on 02 Feb 2025 05:02 PM
Do we just wait it out?
Message posted on 02 Feb 2025 07:48 PM
I've had the same problem, super frustrating.
Message posted on 02 Feb 2025 08:44 PM
Same problem
Message posted on 02 Feb 2025 08:52 PM
Same issue here
Message posted on 02 Feb 2025 08:54 PM
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
