8
This discussion topic has been answered Discussion topic: Problems connecting my HP laserjet printer since new router installed
This message was authored by: Parky06
I recently upgraded to Sky Broadband Superfast. So far so good, except when it comes to my HP  Laserjet M15w which just will not connect to the new router (despite before being easiest printer in the world to set up). I've tried to use the WPS button to reconnect to the printer but it doesn't work.
I'm wondering whether the issue might have something to do with this note in the printer instructions - "only 2.4 GHz band is supported". Is that a possiblity and if so what do I do please? Thanks.
Re: Problems connecting my HP laserjet printer since new router installed
@Parky06
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Yes, that's important.
Do you have a black or a white Sky Hub?
Avatar for Parky06
Black.
@Parky06
username: admin
Avatar for Parky06
@TimmyBGood- you are a genius! That has sorted out what had been vexxing me for weeks. Thank you very much!
This message was authored by: MarkH641
Please could you let me know the instructions for the new (white) hub?
M
@MarkH641
The wireless bands cannot be unsynchronized and renamed on a Max Hub.
This message was authored by: crimson
I will have a similar problem when i buy my new HP printer. I'm just wondered if you have to chop and change with bandwith you're connected to or will it all run seamlessly. For example if i'm using the internet  will i have to switch in order to print something then switch back to use the internet or will it all work automatically and I won't even notice?
@crimson once the printer is properly connected to the network then it should be discoverable by your other devices on the network.. However having wasted more of my life than I wanted connecting network orinters nothing is cerain. HP printer software is better than it was but that is not praise.
