Discussion topic: Problems after resetting router
This message was authored by: ao6889
After resetting the router I can not access facebook. This has happened before and I recall having to alter something in my router settings but I can not remember what. Any advice?
Re: Problems after resetting router
@ao6889
https://www.sky.com/help/articles/sky-broadband-shield-using
Avatar for ao6889
Thank you for that Timmy, but when I click on the link to Broadband Shield to log in, the page fails to load with the blue circle still rotating after three minutes???
@ao6889
Try clearing you cache & cookies or using a different browser
I am NOT a Sky Employee
Avatar for ao6889
Thank you James. Cleared cache and cookies and tried three browsers. Still no luck. Page either does not load or does not display correctly.
