Discussion topic: Problem with wifi
This message was authored by: KerriDarling
Problem with wifi
Keeps going off and on
Re: Problem with wifi
@KerriDarling
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
