This discussion topic has been answered Discussion topic: Problem with only certain websites with wifi
Message posted on 13 Apr 2024 12:32 PM
hello while using my phone or tablet, certain websites or apps i cannot get a respose ... it worked fine 2 weeks ago.
using lan port is fine
i bought a Asus ax82u for better wifi ... using Ap mode and disabled skyhub wifi (sr102)
using google or you tube i have no problem.
reddit app not working
twitter X app not working correctly
ring app not working says not wifi
I have swapped dns from cloudflare to google. resetting my routers , also tried unplugging and turing off asus router....
dunno what left to do
Message posted on 14 Apr 2024 11:56 AM
Solved
Ok so when browsing using my wifi on my phone or tablet i had problems like conuldn't view certain contaent or videos or images... well after many hours of trying many different solutions i did a factory reset on my sky hub (sr102). I thought that the reset button on the the outside of the sky router was ment for a factory reset but realised this is not the case.
If anyone has this sort of problem use the factory reset on the software page accessed by 192.168.0.1
sign in using user: admin pass: sky . the stupid user interface design will then hide the buttons for the reset so just
-click on the sky lettering in white in the top left hand corner,
-now on the right you should see a box Useful Settings and at the bottom facotry reset
hope this is useful
Solved
hope this is useful
Message posted on 14 Apr 2024 03:53 PM - last edited: 14 Apr 2024 03:54 PM
Re: Problem with only certain websites with wifi
@MonkeyinThought wrote:Solved
hope this is useful
On my Sky Broadband Hub it's the 'Sky hub' logo at the top right you click on although I didn't know that little lot was there so cheers.
