Discussion topic: Problem with my broadband in Worthing area
This message was authored by: Sizzles76
Has anyone got any problems with their broadband, I'm in the Worthing (south east) area
Re: Problem with my broadband in Worthing area
@Sizzles76
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
@Sizzles76
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
