Discussion topic: Problem with broadband
Message posted on 11 Apr 2026 05:55 PM
My internet keeps intermittently going off. The lights on the hub will be all green then the WiFi and broadband will go red or no light. The power light will then be red.
Message posted on 11 Apr 2026 06:16 PM
Re: Problem with broadband
@Sue332
