Discussion topic: Problem with broadband
This message was authored by: Clairebonshor
Broadband keeps going down so no WiFi and no t.v
Re: Problem with broadband
@Clairebonshor
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Avatar for Clairebonshor
Hi we have tryed all that . I'm have problems get though on phone
@Clairebonshor
You'll need to keep trying on the phone, when the assistant asks what your problem is just state its a broadband technical issue, then hold through any prompts to go online.
I am NOT a Sky Employee
