Discussion topic: Problem with broadband
Message posted on 27 Jan 2025 05:32 PM
Hello, you have run a check on our broadband and say it is ok however it definitely is not. My children are intermittently unable to play their games consoles and we have the same issue with our phones. We will be able to watch videos and have to turn our wifi off and use our data as it will pause. There is 100% and issue with our broadband.
Message posted on 27 Jan 2025 05:39 PM
Re: Problem with broadband
@Jonnyc1981
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any Openreach visit.
Message posted on 27 Jan 2025 06:02 PM
Yes I have done this. It is not working
Message posted on 27 Jan 2025 06:04 PM
Then you'll need to report this to Sky.
