Discussion topic: Having issues with broadband
This message was authored by: Lindsey29
Hi,  I'm having issues with my broadband.  We've restarted router and still not working
Re: Having issues with broadband
@Lindsey29
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any Openreach visit.
Avatar for Lindsey29
Hi Daniel.  Thanks for this we've done everything to get it back on.  And still no joy,  will contact them thank you.  👍
