2
This discussion topic has been answered Discussion topic: Printer set up with sky
This message was authored by: Rambo161
Does anyone know how to get printer set up on laptop, since having new router installed it wont connect. It says offline or unavailabe, have tried pressing WPS on router but doesn,t work.
Re: Printer set up with sky
@Rambo161
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
@Rambo161
Avatar for Rambo161
Thanks will give it a try
