Discussion topic: Playstation Portal Cloud Streaming does not Work
This message was authored by: Xtopher93
Hi - I have my Playstation Portal that can cloud stream from Sony, however it does not work on the Sky Wifi (White Router Box).
It works fine on all other devices, and I never had issues with BT previously. It works if I tether off of my phone.. I believe it could be the firewall but Sky restricts a lot of the settings on the router, have tried all of the fixes I could think of and those suggested online. Resetting, disconnecting, turning off the Sky firewalls but nothing works (Ipv6 to Ipv4 etc...). Hoping for some help please.
Re: Playstation Portal Cloud Streaming does not Work
@Xtopher93
Have you tried lowering or disabling your broadband shield settings ?
You can do this via the MySky app or online here:
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Avatar for Xtopher93
Yes, was part of the potential fixes I previously tried but still does not work.
This message was authored by: TheJardashians
Currently having the same issue with my Playstaion Portal, unable to connect to streaming service. Had previously worked but suddenly just stopped. Honestly thinking why did I move to Sky, Virgin Media never had any issues
